Branson F3550 Shift Problems
   / Branson F3550 Shift Problems #1
huntfish53
Kingston, GA
Branson F3550
Tractor will shift into range 1,2, or 3. But will not go into gear 1-4, but when you shift to forward or reverse it will move forward or backwards. Gear shifter is in NEUTRAL. Something has to be stuck???
   / Branson F3550 Shift Problems #2
Look for a piece of tree branch jammed in the linkage under there. if not that, sounds like a fork became disconnected inside. LH Range 12&3 is NOT Synchro, but the RH side 1-4 shifter is synchro
   / Branson F3550 Shift Problems #3
It is possible that you have something jammed in the linkage as Linc mentioned, It is also possible that the shifter has gotten the external shifting forks mis-aligned. I did that once on a Century 2535 (Branson 3510),not sure how, but the shifter would not move. It freed up while I was fooling with the lever and every thing went back to working. Take a look at the mechanism at the base of the shifting lever. It probably is something simple. Good Luck. W. Jones
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
