jswann1975
- Joined
- Jul 5, 2022
- Messages
- 13
- Tractor
- branson 7845
Long time reader, first time poster. This tractor has developed a strange problem... When I start it it will barely idle sounds like only one or two cylinders are hitting, will hit three or four times and die, but after starting about five times it will run. Blows grayish smoke that seems to me like it has water vapor in it. It will do this for ten minutes, making thick clouds. As time goes on it will start to run smoother and rpms will start to tick up, then finally it will clear up and run perfectly. I don't think that it is possible that head gasket could have failed because it ran perfectly when parked.
I hate to admit this but I looked everywhere I knew to look for 30 minutes and could not find the dipstick (was thinking of checking to see if there was evidence of water in the oil). Another piece of evidence, it sat in a field for a year without moving and I'm burning the same diesel I put in it a year ago so there could be some condensation in tank. I mostly run old tractors - farmalls and massey fergusons so this is all new to me but I really need this tractor to run for the front end loader. Any suggestions would be appreciated. Kind of hoping draining fuel out will fix it. I've found answers to many other tractor problems on here before.
I know, the foundation of the problem is that I didn't buy a Kubota or Deere, but it is a long story.
