Oil & Fuel Branson 6530 Hydraulic Flow Rate
   / Branson 6530 Hydraulic Flow Rate #1
mcdvi
QLD
Branson
Hi Guys, I have searched high & Low But i Cannot find the Flow Rates for hydraulics on my branson 6530 R, any info would be a big help. Looking at buying a post driver.
   / Branson 6530 Hydraulic Flow Rate #2
Hi and welcome to TBN.
According to the service manual, the tractor has a 16 cc pump for the main circuit. So it would put out close to 11 GPM @ 2600 RPMs. With all the losses, I would say you have around 10 GPM @ 2600 RPMs.
   / Branson 6530 Hydraulic Flow Rate #3
Nope. Not adequate flow for that.
   / Branson 6530 Hydraulic Flow Rate #4
The HD 10 calls for 15 gpm,
however that is for the fastest operation.
All the hydraulics do is extend the cylinder against the springs which provide the driving force.
We use ours frequently will much less flow then 15 gpm more like 6-8 gpm.
Also ours is mounted to a 3 point adapter plate to the SSQA on the loader as we find it much handier that way to get into places.
Thanks For your help guys, Cheers Vic
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
