3-Point Hitch branson 4720h tractor
   / branson 4720h tractor #1
ARNAUDVILLE
ARNAUDVILLE LA.
BRANSON 4720 H
where do the swing chains go on a bran son 4720h tractor. they broke off and I cant see where they were
   / branson 4720h tractor #2
I am not sure what you are talking about? Could you elaborate a bit more?
ITS THE CHAINS THAT KEEP YOUR EQUIPMENT FROM SWINGING .I THINK THEY HOLD THE 2 SWAY BARS AT THE BOTTOM OF THE 3 POINT HITCH.
   / branson 4720h tractor #4
Hmmm. My 4720ch doesn't use chains. It uses one piece of square tubing placed inside a larger piece of square tubing with a series of holes and a pin that let you telescope it's length to limit the horizontal swing of the sway bars. Much simpler, easier to use, and more effective than the chains that are on my old Massey. I'm surprised that your 4720h uses chains. Do you want a picture of mine?
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A50397)
2021 New Holland...
2015 Kioti RX6620 Tractor with Loader (A50490)
2015 Kioti RX6620...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
UNUSED Four-Layer Black Metal Storage Shelf (A50860)
UNUSED Four-Layer...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2013 Fiat 500 Hatchback (A48082)
2013 Fiat 500...
