Branson 4720 Battery
   / Branson 4720 Battery #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
Anyone know off hand what the cold Cranking Amps are in that tractor. Did nt see much in English writing on the battery.
batteries 4-5 years old now and the first winter where it doesn't start . Cant turn over the engine in the cold.
No colder then last year but had no problem last year. Too freaking cold to pull it today to get a better look.
-16C and blowing hard Tractor will start well in 2 days when its +6 and raining.
Whats one more battery to change atv and truck done in the last month!
   / Branson 4720 Battery #2
I have a Jinma 554 tractor - 55hp. The battery for this tractor is 900cca and is still original and works just fine.
Maybe you have some bad grounds somewhere - of course wait until temperature is warmer than -16C:D
I was planning on an 800 ish CCA battery but was hoping that someone would chime in and say they're 600 from the factory.
   / Branson 4720 Battery #5
My 2400H has an Interstate (USA) battery.
It also has the built in Block heater.
So far, So good...
   / Branson 4720 Battery #6
So far, So good...
Same here but I only got the tractor in October.
   / Branson 4720 Battery #7
Install the highest CCA battery with the highest amp hours that will fit in the battery box .
Exactly my method. I measure it out and order max output from there. Good idea to note the positive and negative orientation of the posts so your cables reach. Oddly, this is not a standard.
Block heater is not going to help me as I have no power where the tractor is housed.and a power cord at 500' may not have much left at the plug.
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
Toro Workman Cart (A50322)
Toro Workman Cart...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
1997 EZ Spool Trailer (A49461)
1997 EZ Spool...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
