I have a issue with the split fuel tank that the 2014 4520r uses. I found out that they made a change for the better on the 2015 model. The tractor will show empty on the gauge and if I am on a slight grade it will act like its runs out of fuel. So I am certain the gauge is correct. When I go to fill it back up it only will take 5 gallons, and the gauge shows full. I don't think the fuel is going into the secondary tank. The fuel capacity is 9.3 gallons. I am assuming that there is only one fuel sender and its in the primary tank. I called bransons customer service and talked with a technical rep. He told me that there is no pump involved in pumping fuel into the other tank. I was lead to believe that it has to spill over into that tank. I have a motocross track on my property and believe me if it was going to spill over it would on my property. I love the tractor but this is a joke. The tractor burns just over 2 gallons an hour so I have to fill it often. It has only one filler cap on the drivers side. This baffles me. I was wondering if anyone else is having the same problem. I get the feeling that branson really screwed up and they just don't want to admit it. The tech rep told me that the 2015 tank will not fit on the 2014. He claims that this has not been a problem but if that the case why did they make a change in 2015. The 2015 tank is a one piece tank while the 2014 tank is two tanks connected by hoses.
