branson 4220i
   / branson 4220i #1
jim y
wendell nc
kioti
I have a branson tractor 4220i.some times tractor will throttle up on its own.I have to shut tractor off then restart for it to throttle down.I think it may be an injection pump problem.Has anyone had this problem.
thanks Jim
   / branson 4220i #2
That is what it sounds like. Or possibly a week spring in the pump as well..
   / branson 4220i #3
Having a problem with my 4220. It won't idle. Just revs up to 3000 rpm. Mechanic says it needs a new pump and will cost $1500 for the part!!! Only 600 hours on it. Are there any other possibilities? I think it is a 2005 model. Any lower prices?
   / branson 4220i #4
Could be a froze up throttle cable but mechanic should have checked for that. Otherwise thats the going rate for that pump. Will want to make sure you get a pump for a 4220 and not a 3820. Electronic manuals are screwed and got the part numbers messed up. I always consult my paper manuals for the correct number. Pump manufacturer has a contract with Kukje that keeps parts for the pumps themselves out of the hands of injection pump rebuilders. Make sure that the lever on top of the pump that has two cables attached is moving back and forth between the stops for it.
Hay Cutter (A48837)
Hay Cutter (A48837)
2022 Club Car...
UNUSED 2025 INDUSTRIAS AMERICA FT510 DUMP TRAILER (A50459)
UNUSED 2025...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2022 Club Car...
New/Unused 12ftx20ft Steel Carport (A48837)
New/Unused...
