Branson 4215 Throttle Cable
   / Branson 4215 Throttle Cable #1
yooperdave
Veteran Member
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
How hard is it to disconnect the throttle from the forward/backward foot pedals?
I do not like the throttle backing way off when I am trying to dump my bucket - it slows down the hydraulics.
All of my prior tractors had a hand throttle - set it and forget it.
TIA
Yooper Dave
   / Branson 4215 Throttle Cable #2
No need to disconnect. Use the hand throttle which your tractor also has. It's that vertical lever on the right side of the steering wheel.
That's what you would use to set the RPMs at the PTO.
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2021 Kubota SVL 97-2 (A57148)
2021 Kubota SVL...
2012 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2012 GALYEAN 130...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
1694 (A58375)
1694 (A58375)
REYNOLDS 14C SCRAPER (A58216)
REYNOLDS 14C...
