branson 4020, lights, electrical problem
   / branson 4020, lights, electrical problem #1
4020
My father-inlaw has a Branson 4020 with an electrical problem. Basically if you turn on the lights, turn signals, hazard lights, shift into reverse (reverse light) or step on the brake. All the lights dim and the gas gauge goes to empty. The battery and alertnator are fine. I have disconnected the multif and the lights dimunction light//horn switch and hitting the brakes still does in the gauges. I also disconnected the brake light switches and had the same problem by switching on the lights.
So I've eliminated, battery, alternator, multifiunction switch, and brake light switches. I've also started checking grounds.
If it was a short large enough to pull down the electrical system I would expect a blown fuse or some melted insulation or at least smoke. It is not doing any of that even after a couple of minutes.
I'm fresh out of ideas. My father-inlaw says it seemed that moving the steering column helped for a while but not anymore.
Thanks in advance!
   / branson 4020, lights, electrical problem #2
G'day don't know your machinee but i would be looking for a dirty ground somewhere
Jon
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Pallet of Tile (A50860)
Pallet of Tile...
2008 Toyota Prius Touring Hatchback (A48082)
2008 Toyota Prius...
1984 ASPT 30ft Pole S/A Towable Trailer (A48081)
1984 ASPT 30ft...
2019 Chevrolet Malibu LT Sedan (A48082)
2019 Chevrolet...
2004 Chevrolet Venture Mini Van (A50860)
2004 Chevrolet...
