Branson 3725h zerks
   / Branson 3725h zerks #1
TomIre
College Grove, TN
Branson 3725
How many zerks have you found on your Branson? Besides the ones on your loader?
I've hit a couple on each of my 3 point arms but I wonder if I'm missing sone? Anywhere else I should be looking?
   / Branson 3725h zerks #2
You have two on the tire rods (one per side).
Two on the pivot blocks for the front axle.
One on the adjustable side link for the worm drive.
A couple of them on the Pedals, and the geared tractors have two more (one on each side) very hard to reach for the throw out bearing pivot shaft.
Models with draft control also have another one on the pivot block for the top link.
From memory I think that's all. The pedal and clutch rod ones are kinda hard to see and reach.
   / Branson 3725h zerks #3
The brake pedal pivot ones are pretty hard to reach, and I have long arms.
Thanks - I've been missing them! I assume they are reached from underneath the tractor? I have a hydro model. I'm now guessing their must be ones for the forward and reverse pedals as well?
   / Branson 3725h zerks #5
I could *barely* reach mine from the back, crouching down behind the rear tire. But like I said, I have long arms. I looked under from the side, and without actually crawling under in the dirt, it looked like the fuel tank would be in the way and blocking the view.
I'll have to look again at the forward/reverse pedals. I could be missing those too!
Lol.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
(APPROX 80) 2" X 3" X 16 3/4" ANGLE IRON (A51247)
(APPROX 80) 2" X...
2019 John Deere 1023E Tractor (A51573)
2019 John Deere...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
