Branson 3510i questions
   / Branson 3510i questions #1
Yalerider
Woodland, Washington
Branson 3510i w/FEL
I have had my Branson for a couple of weeks, very impressed. I have a couple of questions.
1. I only have the position control for the PTO. I believe the second slot is for the draft control. I did not get the lever for this, is it optional? Not sure if I would need it anyway.
2. How heavy is this tractor? The weight listed on Branson's site is without an FEL I believe. Iwonder what it weighs with 700#s of weight in the rear tires, FEL and fuel?
   / Branson 3510i questions #2
You picked a great tractor, The draft control is only on the 20 series tractor, and the third slot is for the remote hyd, the loader weighs about 750 lbs, and the tractor is 3756, for a tolal of 4506 plus your fluid. I was just reading another post you have about the check valve, I will post a photo later to show there location. Have Fun
Thanks! I would imagine the Industrial tires probably weigh a little more than the ag tires as well.
   / Branson 3510i questions #4
I believe the knob next to right heel(when sitting in the tractor) is the control you are looking for. I have a regular 3510 and I think that is it.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
Richie Water Master 1200 Trough (A50774)
Richie Water...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
Caterpillar CB-54 XW (A50120)
Caterpillar CB-54...
