Branson 2910i PTO switch
   / Branson 2910i PTO switch #1
jb78155
TEXAS
Farmall Model B
Here we go... I bought my Branson about a year ago and it seemed everything was working well. I had only been using the front end loader to clean up around the place and i decided to go ahead and get a tiller for it about 6 months ago.
That is when I found out that the pto switch would only work in the independent position no go in the link position. To make a long story short its still under warranty and its been at the dealer three weeks...he says they have worked on it but just can't figure out what is causing the problem. any ideas on what to do?
   / Branson 2910i PTO switch #2
I've got a 2910i but I'm not very familiar with the "link" position. Does that link it to the clutch or to the 3pt?
The pto switch on my Branson has three positions Link OFF Ind. Link is supposed to make the pto clutch operated ie let the clutch out and the pto spins push it in and it disengages, independent the pto is on all the time. I have heard that Brason discontinued this type of switch.
Dealer just called and they are going to replace the entire wiring harness for the pto...hopefully that will get it working correctly.
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
