Branson 2810 Leaking FEL Quick Disconnect Solved
   / Branson 2810 Leaking FEL Quick Disconnect Solved #1
Melsman
Branson 2810
One of the issues I set out to solve on my 'new to me' Branson 2810 was a very leaky hydraulic quick disconnect on the front end loader (FEL). I figured it was a bad O-ring, which shouldn't be hard to change... right? If you can find a new o-ring, that is...
The first thing I realized is that the Parker Series 6600 #6603-6-6 female connector on this tractor is not sold in the US (generally) and I couldn't find one at a Branson dealer. This is because it's the BSP thread model. (The male side is the 6605-6-6 - also not generally available in the US.) But I thought I might luck out and find the O-ring (part#JT020115N0674) in stock in the US... but no. But then it dawned on me; the o-ring for the NPT (US) Parker 6601 coupler (#50001-115-0010) should be the same as the o-ring for the BSP 6603 coupler, since they are both 3/8" barrels. And I was able to find the #50001-115-0010 o-ring on-line. So I ordered four and when they arrived, I installed them. They were a perfect fit.
The tricky part when installing the o-rings is to get the o-ring behind the little nylon backer ring (part #411805, BTW). However, with a little patience, the o-ring slipped into place behind the backer ring and sealed the QD properly. No more leaks.
As a note, the o-ring's dimensions are: OD-0.9"; o-ring thickness - 0.1"; material - Nitrile
Melsman
   / Branson 2810 Leaking FEL Quick Disconnect Solved #2
Melsman
Good stuff, thanks Melsman!
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
William Nash HB-1030 10ft Hy-Brid Electric Scissor Lift (A50322)
William Nash...
New Idea 483 Round Baler (A50774)
New Idea 483 Round...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
