Branson 2810 Headlight/Horn
   / Branson 2810 Headlight/Horn #1
jbe
Missouri
Branson 2810
Hello All,
I am new to the forum and just bought my first tractor. Branson 2810 and so far I am really pleased with it.
One problem is that both headlights and the horn do not work. They are all on the same switch. Also on that switch are the rear turn signals that do work.
I checked the fuse and it is good. I can't imagine both headlights would be bad already with only 125 hours on the machine.
Any ideas on where to start or what to rule out?
   / Branson 2810 Headlight/Horn #2
G'day it sounds ti me like you are not getting any power into the switch pull the switch out and check for power at the plug I do not have a wiring diagram for your tractor so cannot tell you what colour wire it should be, it is either no power or a dodgy switch. I would have thought at 125 hrs it would still be under warranty I would talk to the dealer before you go to far if not under warranty they might fix it for parts only or come to some sort of deal. Best of luck:)
Tennant Floor Sweeper (A50322)
Tennant Floor...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2012 Hyundai Sonata Sedan (A50324)
2012 Hyundai...
2006 Reelmaster Toro 3100D Commercial Mower (A50322)
2006 Reelmaster...
John Deere 6175M (A50120)
John Deere 6175M...
2018 Ford F-150 XL (A50120)
2018 Ford F-150 XL...
