Branson 2440 Brakes
   / Branson 2440 Brakes #1
gepmgmac
Branson 2540
My 3530 has a sticky right brake. I can sometimes get it free but not often. Any suggestions on how to fix this?
   / Branson 2440 Brakes #2
It will help once we figure out what model you have. Right now, you mention 2540, 2440 and 3530 and none of those are Branson models.
Is it the 3520? The older 20 series had some issues with the brake pivot shaft that enters the axle housing would get moisture and rust making it stick. Best thing without taking it apart to clean the shaft and possibly add a grease zerk is to keep spraying it with some sort of penetrating fluid of your choice till it loosens up and then with some sort of lubricant.
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
Makinex Electric Powered Hand Truck (A52377)
Makinex Electric...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
