Branson 2400h
   / Branson 2400h #1
chewnins
Warren, OR
None Yet :-)
Newbie here, I have been borrowing an older Kubota B7000 or an older 8n from neighbors here for the last few years, and it is finally time to bite the bullet and buy one. I am "blessed" to live near a larger city and have my choices made all the harder by the numerous options.
Here is what I have:
~4 acres flat all pasture that blackberries are starting to claim cross fenced (48" gates, minimum between posts 56")
~300yard driveway
I want to be able to use at least a 4ft brush hog although a 54-60" would be nice. Want to be able to till a small (40x60-80') garden, move barkdust/firewood, run a post digger and grade my driveway, possible backhoe later, but could (wife will say should) rent.
I am also a taller individual and have found any of the BX or Mahindra Max line far too cramped to be safe (knees bump everything). I was going to look at New Holland and noticed the dealer also carried Branson. I have been lurking on the site for a while now doing research, and can't find anything about the Branson 2400h units. I drove one around on the lot, and there was alot more room especially with the side by side HST pedals. Just wondering if they are going to last or if I am better off continuing the search.
So far I have test driven/rented:
B7100 (look like a clown on it)
B8200 (slightly less clown like, didn't like the no-PS and wobble HST, but it is for sale)
8n (plenty of room, no bells and whistles, loader a pain)
Mahindra Max22 (can't turn), Mahindra 2216 (want an HST, but could fit)
New Holland Boomer 25 (nice, but a little out of my price range)
I have not looked at Deere yet mainly due to my budget, but am planning on getting over there soon. Are there any others in the ~12-13k w/fel that I am missing, or do they not exist?
   / Branson 2400h #2
If you are looking at new you will be hard pressed to find a Kubota or JD for less than 18K with a FEL and MMM. Kubota B2620 or JD 2520 would be similar size and used they are all in the 15K+ range.
I have not seen nor driven the 2400H but the dealer did give me an attractive quote. Only question I have is the 1200X FEL Vs the 00. The 00 seem a little under powered for this size tractor. The 1200X seems comparable to JD and Kubota models.
Quality concerns: Don't have an answer for that. Seem like a heavy built machine but it's what inside that counts.
Roy
   / Branson 2400h #3
Hi chewnins
http://www.tractorbynet.com/forums/zetor-century-branson/242683-branson-2800h-bl00-loader-new.html
I'll give the branson/kukje "00" series a thumbs up. If you want to run the larger brush hog you might want to go with the 2800H. It is the same 1.1 L motor as the 2400 but with a turbo added. The 28 HP is conservative, and with these bransons the PTO HP is high in comparison ~ 23 PTO HP for the 2800.
I've only had my 2800H for a month and 20 hours but TBH I have no complaints. You'll not see very much info about the bransons online on forums. (which is a good thing because broken Bransons are not prodding owners to go online for answers or to gripe)
I wanted to stay under 25K for a sub compact but ended up going to the larger size tractor with the 16" rear wheel. The 12" rear wheel on the subcompacts is a little small IMO and equivalent to a garden tractor.
There is a branson dealer in central oregon that seems to have great prices and move a lot of product (even on ebay). I almost ordered through him but chose to stick local and went with a demo unit he had. It was 12K for 2800H with the BL00 loader.
BL00 loader vs. 1200X: I wanted and drooled over a 1200X loader / 6430X BH package for teh 2800H and got a quote for 18K for those from the central oregon guy which my local dealer could not match.
BL00 loader:
The BL00 loader is made by Ansen, a sister company to Kukje in south korea. In addition to the below I was happy to see that Ansen makes the big loaders for even the 8050 series tractor (the BIG one). You can see the Ansen sticker on the 8050 in the branson calendar if you look closely :)
At the time of purchase, I hesitantly went with the BL00 setup he had (because I wanted the 1200X with more load capacity listed and the quick attach bucket) on the lot but honestly I like the little loader a lot. It digs and lifts an overfilled pile of wet dirt with no problem. It seems like it will almost want to tip the back wheels up if too much load were lifted even with water in the tires and a 5" box scraper attached. The BL00 loader is BEEFY - check out the 1" plate around the frame area. Sure it isn't one of those nice hydroformed curved loaders etc. like the 1200X but that is OK. One thing I was surprised about was that the valve doesn't let you use two hydro circuits at once unless one is going down, of course. But you can't do the 7 oclock position tilt and lift. No problem though, it doesn't slow me down much at all and I've gotten fast at digging up the dirt piles from the box scraper and filling the bucket with no issue.
The 3point hitch works GREAT, no issue with jumpyness etc. and I was happy to see the position control on the 2800 series.
Motor:
Kukje makes rebadged JD (6000 series I believe)
Kukje is contracted to make the cummins A series motors as well, which is what is in the 00 series. It *is* an unbadged cummins A series 1.1L. I am a big cummins fan and have had numerous dodge diesels over the years that I have restored bought/sold etc. I was very happy to see a fleetguard filter on the little motor when I first popped the hood. The turbo is a great feature that adds power and gains fuel economy. All diesels should be married to a turbo IMO... That feature alone (cummins turbo diesel) puts branson ahead of the rest. I know yanmar and kubota are good but they have mastered the econo-engineering at this point whereas the Kukje/cummins 1.1 A series is a true industrial motor with hardened valve seats, forged steel crank and camshafts that are made to last.
I was a hardcore JD green dyed in the wool lover for as long as I could remember and I really assumed that I'd get one some day. But the smallest "True" JD (besides the new 1 series subcompact with a yanmar) is the 4120 with the JD powertech. If I'm going to buy a japanese motored Japanese tractor I might as well consider all makes/models.
I did ALL of my homework and visited ALL of the dealers within a 100 mile radius of me and branson got my business.
If you want stories from my other brand experiences and what made me NOT choose them we can go there as well. But this is way too long as it is (guess that is what happens when you are flying across the country with nothing else to do) :)
   / Branson 2400h #4
papecat,
appreciate the information on the BL00 Vs the 1200X. I asked my dealer to quote the cost difference since part of the reason I am looking is for more loader capacity vs my BX1850. The BL00 is rated about 50% more lift than the BX while the 1200X is 100% more.
I would also be using the 3PH for a 4 ft bush hog and 54" tandem disk that is around 700 lbs or more. The BX will barely lift it without the FEL on. 100 lbs of suit case will not keep the front on the ground. I want to dig / transplant some more small trees with FEL and the little BX struggles with this task. Not the tractors fault either.
Is the differential lock, HST pedals, & brake all on the right side? (Literature does not give a real clear picture of this) If yes, how many right feet do the koreans have? :)
Like you I was raised JD green, owned some Fords, now considering Branson. Dad will roll in his grave to see me on "Red" tractor....
Roy
   / Branson 2400h #5
The FWD/REV HST, RT/LT Brakes, AND Diff lock are indeed on the right foot.
With these 00 bransons the Hydro models came out after the original geared models. They seem to simply be geared models set up with a clutch and everything but with Hydros plumbed in. I like it though. I can heel toe the Diff lock and Fwd hydro with no problem. I like having the right/left brake option as well. If I really needed to do a sharp one wheel brake turn I can with the heel toe method as well or put the cruise control on momentarily. It is something that they didn't simply remove from the standard trans setup. My dealer told me it was redundant but also to maintain street legal / tag eligibility it needed brakes. I use the brakes on a hill to swap from H to L etc if needed to keep from rolling that is about it. The parking brake setup works well too.
   / Branson 2400h #6
papecat,
again many thanks for the info on the foot controls. I am waiting for the dealer to get one of these on the lot to do the test drive. He said he should have one first part of June so that isn't to long of a wait:)
Roy
   / Branson 2400h #7
I bought a 2800H the end of January. At that time, Branson had a "free FEL" with total cost out the door of $13250 with a 4 year warranty. That was with loaded tires and the BL00 Loader. They wouldn't even talk about exchanging the FEL for the 1200. Dealer said he wouldn't want to upset me with the price increase. He said that it simply wasn't worth it for what the BL00 is going for. I got it home, played with it a little, didn't have room in the pole barn at that time, so it sat under a tarp outside. I used the FEL to move some snow after a big storm. The tractor started on the first try and ran great. I have a KingKutter 4' brush hog, it turns it well and I've mowed some pretty big saplings without any problem. Implements I have are: 6' back blade, 4' box blade, 5' York rake, bucket forks and the brush hog. I recently passed the 50 hour mark, right now have 61 hours on it and did my own fluid changes at 50 hours. The purchase included filters for that oil change and a set of maintenance manuals for the tractor and the engine.
I've moved about 80 cu yards of sand from the road in front of our house, put down 100 cu yards of crushed limestone and that little tractor never missed a beat doing it. Like has been said, the BL00 loader is a beefy one and it'll lift the rear tires off the ground if you're not careful.
We've got about 10 acres of gently sloping wooded property that goes down to the lake. I'd looked at different brands, but for the money, I'm glad I chose Branson. It does what I need and I've still got less invested than the local JD or Kubota dealer wanted for a comparable tractor alone.
   / Branson 2400h
Thanks for the responses. Last weekend I checked out a JD 2040 and a Kioti CK20. Neither seemed to fit as well, or be priced as nicely. I will be visiting my local new holland/branson dealer again this weekend to try and figure out if the 2800 or 2400 will be coming home with me.
Do you think the 4 extra ponies is worth the extra 1000? What about extra maintenance from a turbo, I know they have been used on trucks/cars for a long time, but still worries me a little about one more thing to break.
   / Branson 2400h #9
Chewin,
What are you going to be doing with this tractor. The only time you would notice the extra ponies is doing heavy PTO work. I doubt you would notice much difference on the draw bar pull since I suspect the tires will probably spin before the engine works to hard.
Turbo's require a little more care but not enough to scare me away. Biggest concern with a turbo is to let the engine idle so they can cool down after being run hard.
good luck on your decision
Roy
   / Branson 2400h #10
The way the dealer explained it and what I found out when I started using the bush hog is going uphill. As I said, our property slopes to the lake. The Branson tractors ( I suppose most tractors in this size) are pretty narrow and I just don't feel comfortable hogging with the slope, so I go uphill and downhill. On the downhill, there's no problem at all, but on the uphill, the extra few horses (from what I can figure) make up for the slope and I really don't need to slow down to keep cutting as usual.
As for the wheels spinning before the engine bogs, That's exactly right. Even with loaded tires, in sandy, loam the wheels just keep on spinning even if the forward progress slows down. I'm not really concerned with that, it's just something I've grown accustomed to and raise the bush hog a tad and get traction back and keep on mowing.....
I was also concerned on whether to get the 2400 or the 2800. For the extra $700, I decided to go for it, and I'm glad I did.
The one thing I do every time I am done using the tractor is let it idle for about 4 or 5 minutes. From my days of early Ford 7.3L turbo engines, the easiest way to "kill a turbo" is to shut it off when it's still "cherry red" hot. In fact, now Ford offers an option that allows you to leave the truck running and it will monitor the turbo temp and shut the truck off when it's cooled down. On Bransons, no such option, just let it idle while you store the tools, etc and you'll be fine. I'd think (might be wrong here but I don't think so) that if anything was going to happen to the turbo, it would be during the warranty, so take care of the tractor and don't worry about the turbo reliability, I think you'll find it's as reliable as any other comparable tractor. Best of luck with your decision. let us know what you decide to do.
TPM 16 Mini Excavator (A49251)
TPM 16 Mini...
2015 Ford F-450 Knapheide Service Truck (A48081)
2015 Ford F-450...
Ryobi Sliding Compound Miter Saw (A48837)
Ryobi Sliding...
Pallet of (5) 8 Lug Misc Wheels (A48837)
Pallet of (5) 8...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2022 Caterpillar 304 Mini Excavator (A46683)
2022 Caterpillar...
