oldnslo
Super Member
Hi all,
does anyone have any experience with the MMM option on the 2400 or 2800 tractors? Dealer does not have one on the lot and the sales brochure doesn't answer these questions.
Interested in how easy or hard it is to attach and remove the MMM. I.e. pull a couple spring loaded pins and slide the deck or or remove 10 hair pin clips and linkage assembly like some of the older Murray mowers..
Does the MMM do a decent job of cutting the grass. No major scalping issues or uneven cut on a reasonable smooth yard. Not looking for golf course appearance.
Does it use the same lift system as the 3PH? If yes can the deck be locked in the raised position so you can use 3PH implements without removing the MMM.
Can you use the FEL with the MMM attached? I have not seen any pictures with both implements attached... Don't do this very often with my BX but is a nice option.
TIA
TIA
