MESSMAKER
Veteran Member
I may end up buying new if I can't find used so what are the brands that are solid but won't break the bank. I need a 5 or 6 foot box blade and a 5 foot RC.
I know these brands are top notch but don't they end up being a bit more expensive than some less known brands?Land Pride makes an outstanding line of products for the money. Bush Hog and Woods also have very good reputations.
I have a Frontier 4'. I got it with my tractor at the JD dealer. At the time I was a complete tractor newbie, never owned or operated any of this type of equipment, but am generally familiar with machinery and what is built heavy or wimpy.
That said, the Fontier seems heavily built when comparing the thickness of steel used and the weight of the thing. I figured it would be indestructable for my my use. However that has not been completely true! I've bent the main body on stumps, I've bent the blade carriage, I've bent the 3pt hitch pin bracket. I'm really glad I didn't buy a light-weight brand.
I'm not using it for mowing field grass. It's being used off-road, in the woods, thru the ditches, pushing over saplings with the FEL, then grinding them up with the RC and stuff like that. Lot's of rocks and hidden stuff to run over.So, just consider your use before you decide how much you want to spend.
