Brand new CB65 backoe problem- UPDATE
   / Brand new CB65 backoe problem- UPDATE #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
Got excellent dealer service to repair a bad seal in the backhoe ram. As explained in an earlier post, even with the engine running the backhoe would slowly drop.
Once a new seal was installed, all was well. But, after a few hours of digging, the problem returned. Another call to the dealer. The factory asked that I warm things up well, then extend the backhoe and turn the engine off. They wanted me to measure how many inches the ram extended (bled down) after ten minutes with the engine off. The measurement was easy. It had bled off the full extension of the ram after only 5 minutes.
I reported this back to the dealer. Fortunately, the hoe is useable although its a little annoying that it moves on its own. I'm waiting on word back, but the guess was that they might want to replace the entire ram. I'm not a mechanic, but I'm wondering if there is something internal that is scoring the seals and causing them to leak.
   / Brand new CB65 backoe problem- UPDATE #2
Sorry to learn that the leak has returned and hope the dealer is able to fix it soon.
   / Brand new CB65 backoe problem- UPDATE #3
Sounds like they are at least trying to go the extra mile to get it squared away. Let us know...
   / Brand new CB65 backoe problem- UPDATE #4
My wild guess is, it was made out of tolerance.
   / Brand new CB65 backoe problem- UPDATE #5
Just a thought: bad control valve?
A very good thread I read a while back ( I believe it was HEF) made a good point.
The cylinder rod, moving into or out of the cylinder, changes the volume of the cylinder. Fluid, being virtually incompressible, would prevent rod from moving (I likened it to putting your finger over a syringe and trying to move the plunger).
The point they made in the thread was that bad seal shouldn't cause cylinder drift...
Hope you get your hoe fixed soon.
DB
   / Brand new CB65 backoe problem- UPDATE #6
Sorry, that's incorrect.
There are two half's to a double acting cylinder.
If the seal between the two, does not hold, the fluid can leak from one side to the other.
The side that has the weight, or force on it, will have higher pressure, which can leak to the lower pressure side.
That is called an internal leak. And, that's what causes the drift down. Few machines don't experience it to some extent.
I've fixed plenty of cylinders, that had this problem.
Yes, there are other things, like check valves, and external leaks, that can cause this too.
I would expect, they will be replacing the cylinder.
   / Brand new CB65 backoe problem- UPDATE #7
Sorry, that's incorrect. There are two half's to a double acting cylinder. If the seal between the two, does not hold, the fluid can leak from one side to the other. The side that has the weight, or force on it, will have higher pressure, which can leak to the lower pressure side. That is called an internal leak. And, that's what causes the drift down. Few machines don't experience it to some extent. I've fixed plenty of cylinders, that had this problem. Yes, there are other things, like check valves, and external leaks, that can cause this too. I would expect, they will be replacing the cylinder.
Yes, that could be the cause. But, read the thread: Understanding hydraulics and cylinder drift The point I took away is: if you took the cylinder filled with oil, plugged the hose ports, then tried to force the rod in or out (with bad seals or even without a piston on the end), the rod is physically changing the volume of the cylinder (and acting on the fluid).
I can understand the difference between theory and field and that there may be other variables involved.
I hope it's an easy fix and he's up and running soon. DB
   / Brand new CB65 backoe problem- UPDATE #8
Plowhog,
As I recall you just got your unit recently. Did you notice this issue from the get-go?
Seems if it drops all the way in 5 minutes that its worse than before the seal was replaced.
Its nice to have a good dealer and warranty at times like this . . its even better if the 5 year warranty was still "new in box" amd shiny at the end of the 5 years :)
Fingers crossed it gets better soon :)
I did not notice it at first. But I am a total greenhorn around a tractor so that doesn't mean much.
As best as I know, I am pretty sure it developed after I used the backhoe for a while. I noticed it dropping after having done digging for a while, and noticed that it seemed out of place. So, I do think I would have noticed it earlier had it been there when I first started digging.
Once the seal was replaced, the hoe did not move or drop at all. Zero. I'm pretty sure this means that the new seal fixed things, and then something internal caused that new seal to also go bad. The wild card is the fluid temperature. When the seal was replaced, the temps were only on the low side as I ran the tractor only long enough to test it. Since all seemed OK I didn't go any further. In hindsight, it would have been better to immediately dig with it and get all the fluids to normal operating temperature. That would have been a better test, and as it turns out, it might have revealed the problem again on the spot instead of waiting for the next tractor use.
   / Brand new CB65 backoe problem- UPDATE #10
Plowhog,
I've just a little less than a year of actual "tractor" experience. My past use of skidsteers and trenchers only applied a lityle to tractors. What I've learned in the last 10 months is . . operate safely and expect to always be learning. I don't think you did anything improper . . but now you've learned to double check repairs to see if they actually got repaired lol.
Keep the paint shiny . . its still a new tractor that just showed it wasn't quite weened away from the dealer yet . . it needs one last visit and then its ready to rip without getting homesick lol.
Its going to get better soon. :)
P. S. This spring I'll take mine in for its 50 hour (probably actually about 85 hour). Rojo (spanish for red) has a couple little things that need adjustment at the same time too. :)
2018 JLG 3246ES 32FT. Electric Scissor Lift (A49346)
2018 JLG 3246ES...
Non running toro mower (A48082)
Non running toro...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2017 Ford Transit 250 Cargo Van (A48081)
2017 Ford Transit...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
