Bran New Cub Cadet ZTX5-54 inch
   / Bran New Cub Cadet ZTX5-54 inch #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Just picked it up yesterday. Read the so-called manual. Does not mention what oil to use, I understand there is a special oil for air cooled engines. What is it or will Rotella T4, T5,or T6 work just as well? How about Mobile 1 5-30? How about a number for the oil filter so I can cross reference to Wix or NAPA. Manual says nothing about the Hydro Gear 3200 transaxles, is there a reservoir, how do you check fluid level? Hydro Gear already told me to use Mobile 1 for fluid in our Dixie Chopper. I haven't checked, but is there a shop manual for these things?
Mowed about an acre yesterday afternoon, worked well. Although the front suspension is not suspension and the Kohler engine will lug down and run over heavy grass, so I know there is some strain on the engine and want the best oil for it. This mower is for our Rod and Gun Club and has to last at least 100 years!
   / Bran New Cub Cadet ZTX5-54 inch #2
You'll get a lot of I use this oil or that, or that's fine. I have no clue if someone understands that air cooled engine oil is recommended then why isn't it on the shopping list. I have barrels of air cooled synthetic oil myself. Kohler has some extended change kits which feature Amsoil synthetic and a notch up on filters.
   / Bran New Cub Cadet ZTX5-54 inch #3
It won't last 100 years. I might last 10 if you are lucky.
   / Bran New Cub Cadet ZTX5-54 inch #4
For my mower, I use whatever oil of the correct weight I have on hand. So, sometimes it gets Kubota oil and I think it’s got Valvoline right now.
Mike
   / Bran New Cub Cadet ZTX5-54 inch #6
My CC came with two manuals, one for the mower, the other for the engine. The dealer gave me the wrong manual for the engine, so I had to download it from the internet. Just Google your engine ID and should pop up a source to download the manual.
For mine with a Kawasaki engine it just said use SAE30.
You can also use Google to find a manual for the Hydro Gear drives.
   / Bran New Cub Cadet ZTX5-54 inch #7
^^^Exactly what my two Cubs came with, one has a Kohler other Kawasaki engine and I changed oil & filters yesterday going by the engine manual.
   / Bran New Cub Cadet ZTX5-54 inch #8
Mobil-1 5w30 will be just fine. Not sure what TomPlum was talking about with a special oil for air-cooled engines.... there's no difference between air cooled and water cooled in terms of oil needed, they run in the same general temperature range with the same general internal components. There should be a hydro reservoir, just go inspect the machine and you'll probably find it.
   / Bran New Cub Cadet ZTX5-54 inch #9
"For a Kawasaki engine in the Cub Cadet ZTX5 54 zero-turn mower, the recommended engine oil type is 10W-30 SAE Premium 4-Cycle Engine Oil."
I'd prefer Castrol or Valvoline.
Manual says first change at 25 hours then every 100 hours after that. Changing more frequently for extreme use or engine longevity certainly would prolong life as well as keeping a clean air filter on it. I wash the foam pre-filter, dry it and spray a little WD-40 on it. It seems to catch more dust/dirt that way.
Just called our dealer to get an extra key and a manual for the Kohler motor. We will be using Mobil 1 5w30 in the trans axel and the motor. This is a beast and rides like one. Have any of you experimented with tire pressure? Manual says not to. Understand lowering all to 15 psi improves the ride.
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
Ram 4x4 Pickup Truck Bed (A49461)
Ram 4x4 Pickup...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
71063 (A49346)
71063 (A49346)
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
