Brakes
/ Brakes #1
robing
My kubota B2150 is leaking fluid from a shaft that controls the right rear brake. A rod connects to a arm that is attached to a shaft that has a spring wrapped around it. The shaft goes into the side of the case. The left brake does the same. It appears that a seal has failed were the shaft enters the case. I would like to repair it myself and wondered if anyone has any suggestions or knows of any manuals that might help.
/ Brakes #2
Can't help with the repair, but tractorsmart.com sells service manuals, and it sounds like you'll be needing one.
/ Brakes
Thanks for the suggestion. Turns out there is a seal behind the rear brake drum that was bad. Easy to access and I hope it as easy to replace. By the way, My dealer faxed me the appropriate manual pages. I will be a return customer to LASHLEY TRACTOR in Quaker City Ohio!
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
