brakes sticking on 4410
   / brakes sticking on 4410 #1
taman8281
anybody have a simpler way to loosen the rear brakes at pivot then tearing it apart
   / brakes sticking on 4410 #2
Welcome to TBN:D
Simple? Not really. You can try to work PB Blaster (my favorite) or another penetrating oil in there while working the brake lever manually-other than that there is no secret. this is a common problem because on the lack-of-use the brakes get with the hydro trannys. Also the return springs are known for breaking.
   / brakes sticking on 4410 #3
This is a very common problem with these units. You can easily fix this by spraying the brake pivot shaft with some penetrating oil and instead of rotating the shaft work it in and out. A free shaft will move about half and inch or so. I use a pry bar and a small hammer. Start by taping the shaft in and use a prybar to get under the lip of the bracket and pull it out. These are tough arms but dont get to crazy with the hammer and pry bar. Keep doing this and spraying oil, within a few minutes the shaft will free up and rotate correctly. I then use fluid film to spray a final lube on the shaft..
Never had to remove a brake shaft to free up... hope this helps!
   / brakes sticking on 4410 #4
Be careful doing any prying, the black housing is aluminum.
   / brakes sticking on 4410 #5
I have a 2004 4310 and I can tell you the housing is cast iron on mine!!
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
(INOP) ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
(INOP) ALTO...
2015 CATERPILLAR RM300 ROAD RECLAIMER (A52705)
2015 CATERPILLAR...
200387 (A51247)
200387 (A51247)
Toro Workman HDX-D Utility Cart (A55787)
Toro Workman HDX-D...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
