Brakes on Bolens G192/Iseki TS1910
   / Brakes on Bolens G192/Iseki TS1910 #1
Rusty9
i didn't realize how bad i needed brakes until i hooked up a rotary cutter. Scary! Does anyone have any sources/prices for my tractor? baby needs new shoes.
thanks,
russ.
   / Brakes on Bolens G192/Iseki TS1910 #2
I can supply with barkes & other parts for your tractor. also manuals.
o.k. thanks. i have all the manuals although i have looked to see what all i need for a brake job. i am assuming new shoes/pads. can you give me price? i am up in Kelowna, BC, Canada.
thanks
   / Brakes on Bolens G192/Iseki TS1910 #4
I emailed you a price.
   / Brakes on Bolens G192/Iseki TS1910 #5
It might not be your brakes. Do you have an overrunning clutch? The spinning rotary cutter will "push" the tractor when you try and stop.
   / Brakes on Bolens G192/Iseki TS1910 #6
I second the need for an overrunning clutch. I run a 4' rotary cutter behind my 1610 with an overrunning clutch I got from AgWest (www.agwestdistributing.com). The rotary cutter has enough inerta that you can't stop without the overrunning clutch.
Jim
never thought about the clutch. Hey JWscott, I searched agwest - they show the overrunning "coupler". is that what you are talking about? seems like a very good idea. i'd guess my 1910 would be the same as yours? i'll check with agwest but do you remeber which one you got?
i'll check the brakes too - i think i may need them anyway. Lens12, i'll be in touch if the brakes are fried.
thanks all.
   / Brakes on Bolens G192/Iseki TS1910 #9
My G194 (TS1910F) had terrible brakes and when I went in to correct the problem I found that the oil seals behind the brakes were shot and the drums were full of 90 weight oil. Cleaning the pads and changing the seals fixed my problem. I got the seals from a local bearing supply shop.
Good luck.
   / Brakes on Bolens G192/Iseki TS1910 #10
thanks all.
Rusty9
I got the 03-31-00660. I think its rated for 45 hp.
Jim
Airco Tig Welder (A51691)
Airco Tig Welder...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
