JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,996
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I have a new (made in 2010) MF2660LP tractor. The brakes are inadequate. They will not hold the machine on a very steep grade with a 215lb man putting all the weight he reasonably can on the pedals. For example, you cannot drag the wheels on a steep downhill. You dare not start up or down a steep grade without being in 4wd as the engine is your only hope of controlling the machine. The "parking brake" is also a disaster in that it takes a weight lifting hero to engage the parking brake and an even bigger guy to unlock it. The parking brake will NOT hold the machine against a moderately steep hill.
Note: The issue does NOT appear to be bleeding the brakes (though I have yet to try that) because both brakes feel and act identically and are totally different hydraulic systems left and right. Isolated. Also, the pedals do NOT feel soft or spongy.
The tractor has only about 6 or 8 hours on it.
I assume these to be design flaws. Comment ?
