brakes front vs rear axle
   / brakes front vs rear axle #1
schmism
Super Member
Peoria IL
New holland TC(33)
Was this just discussed? i think i remember seeing a thread, but couldnt find anything so ill ask.
Advantages/disadvantages about brakes on the front vs rear on a tandam axle.
is there a reason they seem to be on the rear when only one axle has them?
   / brakes front vs rear axle #2
My guess is that if the brakes are on the rear axle of a tandem axle trailer, you would get more effective braking, considering the tendency of a towing vehicle to nosedive if applying the brakes hard. A nosediving tow vehicle would lift at the rear, which in turn takes weight off the front trailer axle. If this was the braked axle on the trailer you would lose braking effectiveness. A bumper-pull would be more prone to this than a goose-neck, I suppose. All tandem trailers I have owned had brakes on both axles.
   / brakes front vs rear axle #3
I ordered my tandem trailer made from a manufacturer in Fresno and they
always put the brakes on the front axle or both. Never just the rear. I
assumed that was cuz the weight would shift forward during braking.
see i see logic for both,
when you weight a trailer (bumper or goosneck) its always weighted front heavy for tong weight... does that mean that the front axle always carries more weight? (i dont know) or less weight because the tow veihical carries some?
was looking at a new(ish) 18' car hauler and it was listed rear axle brakes.
18' Trailerman Trailer 2008 Model
   / brakes front vs rear axle #5
In Holland we put ABS sensors on the front axle of a tandem because its most prone to brake slip.
Over here, the law counts a trailer with brakes on just 1 axle for a non braked trailer. IMHO, practically there is not much difference between 1 axle braked, or no trailer brakes... when comparing risk to cost, getting 2 axles braked when buying a new trailer, is a better investment than an average life insurance policy. ;)
   / brakes front vs rear axle #6
I think they brake the rear axle because when the brakes are applied it will cause the trailer to tend to pull straight. Braking the front axle might cause the trailer to try and piviot around the front axle and turn left or right.
   / brakes front vs rear axle #7
On a tandem set with spring equalizers the front axle will tend to pivot upward while the rear axle will pivot downward when the brakes are applied when moving forward. This is due to braking torque being transmitted through the axles and springs to the spring mounting points, which causes the spring/axle assemblies to act like a swingarm.
One of my trailers is a tandem with electric brakes, and when manually applied with full force and with the trailer empty, the leading axle will actually lift several inches off of the ground.
So, if the brakes are only applied to the front axle, braking effectiveness will be decreased because the more braking force that is applied, the more lift and thus less traction the tires will have.
Jay
   / brakes front vs rear axle #8
In my book, 2 axles = 2 sets of brakes. No excuses.
jb
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
1992 JOHN DEERE 544E (A52472)
1992 JOHN DEERE...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
