brake wiring
   / brake wiring #1
edmartin
Bronze Member
SC, USA
Yanmar YM2000
I'm in the process of fitting the trailer I haul my YM2000 on with electric brakes. Problem is that there were no wiring instructions with the backing plates. There are two wires coming from the magnet, both green. I'm not sure if one should be a ground or what. Any help would be appreciated.
   / brake wiring #2
Log onto the dexter axle site and download the data you need.
   / brake wiring #3
I seem to recall the same problem.
I hookedthe backing plate wires to the white and black trailer brake wires. Worked okay.
Egon
   / brake wiring #4
I've installed the same bits on one of my trailers. Ground either one. It doesn't matter which it is. It does matter that you make good connections. I don't trust crimp on connectors, so I soldered all of mine to be sure. /forums/images/graemlins/cool.gif
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
1270 (A50490)
1270 (A50490)
NORTHERN 3P-100 AG MIST SPRAYER (A51247)
NORTHERN 3P-100 AG...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
