brake sticking
   / brake sticking #1
nwltruck
north west Iowa
'07 John Deere 3320
I don't hardly ever use my brakes on my '07 3320, but yesterday I was pulling a trailer and needed to use them. They worked fine until I wanted to move again, and they wouldn't release. I found that the brake cams where jammed. I had to get in behind the wheels and tap the cams to get them to release. I Know someone here can help. I would be thankfull for Any feedback.
   / brake sticking
With a little research I found that the cams will stick in the housing with lack of use. I will try at working them back and forth to loosen them. Is there any way to prevent this from happening again, or should I just hit the brakes more often?
   / brake sticking #3
Yep. common problem...I think Fluid Film is the best solution for this-as well as using them every now and then.
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
