Brake noise/chatter, questions
   / Brake noise/chatter, questions #1
Ken M
Louisville,OH
New Holland TC21
Greetings, I have a 1999 New Holland TC-21, 1200 hours, "wet" brakes. When coming to a stop the brakes have started to make a growling, groaning sort of sound. When almost stopped, instead of a smooth stop (like they used too) right at the end the brakes grab and the tires will skid the last few inches.
Tractor doesn't get used regularly so I wonder if this is from sitting? Or does this indicate some adjustment or possible repair? I'm not sure where to start with this.
Looking for suggestions. Thanks Guys.
   / Brake noise/chatter, questions #2
Document Moved = online parts manual might help you id stuff.
TractorData.com New Holland TC21 tractor information = look up some serial numbers to find correct parts on the newholland website.
pure random guess, double check your linkages between pedal/s and to what ever it ends up at. you might have a loose linkage. some place with some slack in it. perhaps a few turns of a nut / bolt. or perhaps something like PB blaster / pentrating oil to loosen things up.
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
Ford Tractor (A50120)
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
