Brake controller error
   / Brake controller error #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I have a Teknosa Prodigy(sp?) controller on my 2002 GMC pickup. I don't tow very often, maybe 6 times a year. I've towed with it a couple of times with no brake problems. Normally when I drive the truck, it shows "no trailer" on the display or the company logo. Lately off and on, it says "short to battery, no brakes". It seems to do this more often when its raining or snowy out, but I'm not sure about that.
The truck has the factory wiring for the trailer and brake controller, I just had to hook it up and it worked fine at first. Is this a real problem, or will it be fine when I hook it up to the trailer? Has anybody else had this error when a trailer isn't hooked up? I've hesitated hooking it up to the trailer because I figure the minuted I hook it up it will not display the error.
   / Brake controller error #2
I had the same controller in my 2001 GMC 2500HD...It was acting the same way. When it was wet out I would get the error just as you are and I was hooked into the factory wiring. I never did find the problem. The truck is sold now.
   / Brake controller error #3
   / Brake controller error #4
I am wondering if this could be a GM harness problem??????
Has anyone with a NON-GM truck had this problem??
   / Brake controller error #5
The 7 round plug on the GM trucks have caused tons of issues. Since its been snowing like crazy my guess is the issue is back there. Check not only the 7 pin connections under the spring loaded cover but also the plug on the backside and the wiring.
On my 05 Dmax it was a issue causing the running lights and turn signals to blow fuses.
Chris
   / Brake controller error #6
Chris, It could be snow related also but mine did it in the summer also. The truck could sit through a gentle rain and when I would go out and start the truck I would sometimes get this error.
   / Brake controller error #7
We had that same controller in our F550. We had what we thought was an intermittent short somewhere in the trailer, and literally chased it for a couple of years. It would show a Dead Short error the first couple of times you applied the brakes, and then it would be fine for the rest of the trip.
The last thing we did was bypass the Ford dash harness and get the power directly from the power point in the relay box, with 10g wire all the way through. Solved all of our problems, and gave us 100% more power to the brakes.
BTW, the Ford harness is supposed to be designed to support these controllers. It was the last thing we suspected.
   / Brake controller error #9
Chris
ditto that 1000%.. DP beat me to it. my 7 pin plug on my 00 yukon looked good.. but the plug behind it was green!
I also now try to make a habit of hosing my plug connectors out with a spray oil to disperse water..
soundguy
   / Brake controller error #10
Dielectric grease on the pins and sockets helps with moisture and corrosion problems.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
2016 Isuzu NPR Beverage Box Truck (A51692)
2016 Isuzu NPR...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
UNUSED FUTURE GD47 47" LAND LEVELER (A51248)
UNUSED FUTURE GD47...
Tailgate For Pickup Truck (A53117)
Tailgate For...
