Backhoe bradco backhoe
   / bradco backhoe #1
schmism
Super Member
Peoria IL
New holland TC(33)
Bradco 609
To big for my TC33? (im thinking yes but have never seen one in person)
looks to be a 9' depth with 1700lb weight supporting 12-36" buckets.
if it doesnt have a PTO pump, set up for a skid loader, would my powerbeyond handle it or do i still net a PTO pump?
what would you give for one in good condtion?
   / bradco backhoe #2
I would say definitely too big. Your tractor only weighs 2500# naked. It
DOES deliver 7.6GPM to the implements, however, which is fine for any
hoe with 3" cyl or smaller. If it must be Bradco, consider the 3365 or
3375.
   / bradco backhoe #3
schmism said:
Bradco 609
509/511/609 require at least 9.0gal/min if you run off the tractor. You could run off a PTO pump (I do with my 6000 Mahindra for a 511), but your tractor is gonna get thrown around mercilessly Suggest you try a smaller unit---probably no more than 7 to 7.5 ft unit. BobG in VA
   / bradco backhoe
that was my thought. 609 is currently on local craigslist, thought i would ask. ;)
2004 Mercedes E320 (A50324)
2004 Mercedes E320...
24' Inline Feed Bunk (A50515)
24' Inline Feed...
(4) Split Suitcase Weights (A50515)
(4) Split Suitcase...
International 1086 Cab Tractor 2wd (A52128)
International 1086...
County Line 3 pt 5' Box Blade (A50515)
County Line 3 pt...
