Bradco 509 on a L3710
   / Bradco 509 on a L3710 #1
Anonymous Poster
Epic Contributor
I just bought a 1999 L3710 Kubota tractor with a Curtis cab and heater on it. Will this cab be in the way of mounting the Bradco 509 hoe?? I've been reading posts on the list that say the hoe seat comes right up to the back of the tractor's driver seat. Can the seat be moved farther out without mounting the hoe farther away from the tractor?
Thanks,
Jim
   / Bradco 509 on a L3710 #2
Whatever you find, I'd love to know the answer. I'd suggest calling Bradco directly. I also heard that they offer an extension kit that makes the hoe hang further off the back fo the tractor and that might provide the necessary clearance.
Does the rear window/panel of the cab come off? Maybe it could be removed when the hoe is on?
   / Bradco 509 on a L3710 #3
I have a Bradco 611 backhoe mounted on my Kubota 3710. Yes, bradco does have an extension kit but I don't know how far back it would place the hoe. The seat of my backhoe touches the tractor seat and the seat sits well beneath the rollbar. My guess is it would require a long extension to clear a tractor cab. I would guess it might require 8-12" extensions. Too long of extensions may create excessive stress on the mounting plates/tractor. Call the Bradco people and ask. I have called them before and they are very helpful. They will even fax you parts lists if needed.
   / Bradco 509 on a L3710 #4
A 611 on a 3710? Wow. I was told by Bradco that a 4610 could take a 511 or a 609, but not a 611. Your's works OK?
Peter
   / Bradco 509 on a L3710 #5
Yes it works fine. I really wouldn't want a less powerful hoe or reach. Bradco didn't recommend the 611 for my tractor but were more than willing to sell me the tractor mounting brackets. The 511 has the same reach as the 611 but less hydraulic power. The 609 has the same hydraulic power but less reach. I just use the best of both! My only complaint is I use the tractor hydraulics which put out about 8 gal/minute. The bigger bradco backhoes recommend 10-12 gal/minute. Just runs a little slower than ideal but acceptable. If I planned on using it a lot, I would probably get a 12 gal/minute PTO pump. (pto pump requires removal of lift arms for the placement of the oil reservior) I don't use it a lot but very useful. Last weekend I dug trenches for underground drain tile coming off the downspouts of my pole barn shed. The runoff now goes under the adjacent road rather than flowing over. Next project is to use the hoe to construct 3 retaining walls. The guy I bought the hoe from was a landscaper and used it to dig retaining wall trenches and had it mounted on his skidloader. He now uses a medium sized track hoe.
   / Bradco 509 on a L3710 #6
Wow! In my last post, I just became a gold member. Look out Hayden, I am only 450 posts behind you. Ha!
   / Bradco 509 on a L3710 #7
Now only 449 posts less!
   / Bradco 509 on a L3710 #8
Now only 448 posts less than hayden!
   / Bradco 509 on a L3710 #9
I'm trying to stay ahead
   / Bradco 509 on a L3710 #10
I'm still trying
2020 KUBOTA RTV...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
19009 (A48082)
19009 (A48082)
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
