Backhoe Bradco 11HD fit a Mahindra 4110?
   / Bradco 11HD fit a Mahindra 4110? #1
rnds76b
Willimantic, ME
Mahindra 4110 w/ML112 bucket & Husqvarna YTH24V42LS
Will a Bradco 11HD Backhoe fit my Mahindra 4110? And/or is it heavy enough/too light for the tractor?
The used one I'm looking at has a PTO driven hydraulic pump and attaches to a sub frame on a John Deere 5300.
Thanx for any advice.
   / Bradco 11HD fit a Mahindra 4110? #2
In earlier years, you could order 4110's with the 911 subframe mounted backhoe.
   / Bradco 11HD fit a Mahindra 4110? #3
We sold a lot of the 4110 with the 511's on them and have had zero problems with them. I think the specs are similar and with the correct frame you should be fine.
   / Bradco 11HD fit a Mahindra 4110? #4
The 511 and the 509 both used the same sub frame kit for the 4110, there were called 509C or 511C. Or with the PTO pump and tank, 509CP or 511CP. We sold a ton of the 509C and CP's on the 4110 back in the day. I'm not sure if the 11HD has the same bolt pattern, but if so all you need is a sub-frame kit.
   / Bradco 11HD fit a Mahindra 4110? #5
WOW you got not one but three dealers to answer your question!! :drink:
You should be able to make it work with the right subframe!!
   / Bradco 11HD fit a Mahindra 4110? #6
Kneedeep, there is a partial fix for stupid with Duct Tape, if you strategically place it directly under the proboscis. At least stupid becomes less contagious. After all it is mostly spread by mouth ( stupid has an aversion to written text ). This may not be a total fix, but it is another great use of Duct Tape. Now there are a 102 ways to use duct tape.
   / Bradco 11HD fit a Mahindra 4110? #7
I needed some Duct tape today to fix some stupid at work but did not have any!!
I did make a fellow a promise to plug his probiscus with my boot since I was temporarily void of the proper fix!!!
   / Bradco 11HD fit a Mahindra 4110? #8
A boot may be a good fix for stupid, but then stupid wins. I put up with a lot of stupid in my life, but now I'm retired, and the only stupid I need to endure is my own, and that's the kind even Duct Tape won't cure. Unless I have the wife duct tape me to the bed. Na, that's kind of stupid. See there I go again. :scratchchin:
   / Bradco 11HD fit a Mahindra 4110? #9
As my brother onct said, "Stupid is as stupid does" !!
   / Bradco 11HD fit a Mahindra 4110? #10
Is your brother Forest Gump? Wow !!! :thumbsup:
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
ATTENTION! PLEASE READ (A50121)
ATTENTION! PLEASE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
JLG Skytrak 6042 6,000LB 4x4 Rough Terrain Telehandler (A50322)
JLG Skytrak 6042...
