DennisArrow
Platinum Member
- Joined
- Jul 4, 2003
- Messages
- 766
- Location
- Sugar Valley, Ga
- Tractor
- Iseki TL 2300, Kubota RTV, Kubota B7610
I have a 28 X 40 structure going up......12' wall height.....6x6 posts on 8' centers.........clear span trusses 4/12 on 48" centers........1x4x10' (rough lumber full dimension yellow pine) for purlins/lathe............
that is as far as I am along........half way done with putting up the lathe on 24" centers.........am overlaping the trusses by a foot on each end and staggering them by just laying the one that would butt up to the end of the next directly on top of the next one..........hope that makes sense.........got this recommendation from a Candadian government plan sight that says that doing it this way doesnt put as many nails in a small spot on the truss and makes a stronger joint.....
Over the last few days while I have been installing the lathe/purlins I have had the trusses braced with temporary V shaped braces that I am removing as I install the lathe.......
The structure is getting stronger and more stable.......can actually stand up on top of the lathe/purlins and shuffle from truss to truss without getting seasick from the motion .........I know it will become even stronger as the tin goes up...........
Question..........I used doubled 2x12 for my banding/sill with the posts sandwiched between.......using 3 3" lag bolts on each joint where the 2x12 joins or attaches to the post........hurricane straps on each side to attach the truss to the 2x12s.............OK THE QUESTION...............what angle should the knee braces be?????????.............am not going to put on siding for perhaps a year or so...........right now am thinking of using 6x6 down the side in a V pattern on each post...........one end will fit up between the 2x12s and the other lag bolted to the post.............this will happen to both sides.........in addition I plan to come off the truss down to the post with a 2x6 bolted to the truss and the post.........across the end another V pattern ..............wondering what structural member to use here........across the end there is just a single 2x12.............What angles would you put these braces on???????????????????? Is 6x6 overkill????????........Is a 2x6 on a 30 to 45 degree angle bolted to the truss big enough???????? thanks for the help........Dennis
