Boy took the tractor (495) for a bath in the pond
   / Boy took the tractor (495) for a bath in the pond #1
zdooman
Long story short - my teenage son drove Papa's tractor into the pond.
So I am cleaning, fixing, etc
My problem is we havn't seen the manual, yes we do own one? in a couple of years.
So I am at a loss for what type and how much fluid to put in the front axle.
This is a Case 495 (199?) with the MFD front axle.
Can someone advise me on what kind of fluid to use in the axle and hubs?
Also, what are the fill procedures?
If memory serves there is a spot in the front axle fill that you add oil until its covered. On the hubs they are put to 12:00 and filled till it comes out the hole.
Is this correct?:confused:
what, no one knows? Comon guys!
   / Boy took the tractor (495) for a bath in the pond #3
Front hubs should only be filled half way with 90wt gear oil. If you fill it to the top the seals will blow out.
   / Boy took the tractor (495) for a bath in the pond #4
It's a bit unusual for someone to come up with a question to which no one knows the answer and posts it right away. But at least another new member answered.
Welcome to Tractorbynet, both of you.:)
   / Boy took the tractor (495) for a bath in the pond #5
I've always used 90 wt in the ZF axle, some people use hydraulic fluid the same as the sump.
JOHN DEERE WHP48A LOT NUMBER 107 (A53084)
JOHN DEERE WHP48A...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
