Hi all
Been offered a 5 foot box scraper in good condition for 」345, (about 」600 new)
Im getting a yanmar ym186d at the weekend (its within my budget) and was wondering if anyone could give me some advice of whether the scraper and yanmar combo would work ok.
Tractor is 650kg plus front weight, not sure on weight, with roll bar, plus me 100kg and is 18hp. the rear lift is 260kg (ish) and the box scraper will be about 150-200kg.
Any advice would be really good.
Hello to the UK this Cool, Foggy, SoCal Morning,
Kind of what I think of London weather.
I use a 60" Box Blade behind my 28hp Mahindra Max28 Tractor, (2800 lb.), it works but it loads up and sometimes I need to raise it to lose some of the dirt or this 28HP Tractor will bogs down. Not knowing Metrics, and not going to look it up, if your tractor doesn't have the weight and HP you will be lifting a 60" Box Blade (if you can) and losing the load more often than you think; I learned the hard way.
From this Site, I was introduced to a "Land Plane Attachment" (LP), it has the high sides, two diagonal blades, and has no back which allows the dirt load to roll out the back helping to level the holes and lessening the load on the Tractor. I am still new to this tool, I have a lot to learn, but basically I leveled and squared up the LP to the Tractor on the barn floor, and to start I adjusted the blades to the bottom of the sides. My thinking is it will not dig in but if there is a high spot it would cut it down.
You drive back and forth a few times and after a while things start to level out. I am not sure but if I had more experience or a good teacher I could use the tool more effectively, I am learning the hard way.
So my suggestion, as a Novice, for a tool to level and "maintaining gravel track with potholes" is a Land Plane !
Here is a Video of Everything Attachment using a larger LP, hope you get the idea, you would need a smaller unit but I think this would put less strain on a smaller Tractor than a box blade.
How To - Tractor Land Plane - Gravel Road Maintenance - YouTube
p.s. They make the type that tow behind a vehicle, not sure which type works for you !
