Box Scraper Weight for Kubota 2660
/ Box Scraper Weight for Kubota 2660 #1
Lagos
VA
Kubota 2660
I was planning to purchase a used Woods GB60 box scraper (500 lbs) for my Kubota 2660 tractor. Someone told me it was too heavy for my tractor. I'm planning to use it for dirt landscaping, no rock or gravel. Is it too heavy? Thanks.
/ Box Scraper Weight for Kubota 2660 #2
I have a BX2660 with a 48" BB. Once that GB60 fills with dirt I think it would be a bit much for your tractor to pull.
/ Box Scraper Weight for Kubota 2660 #3
Seems a bit too heavy to me as well. I use a fairly light weight 48" LMC on ours and run out of traction pretty quickly as it fills up.
/ Box Scraper Weight for Kubota 2660 #4
I have a woods 60 inch box blade for my B2400. IMO it's too big for my tractor. It doesn't take too much dirt to bog down my B2400. If I had a do-over I'd go with a 48" or 54".
/ Box Scraper Weight for Kubota 2660 #5
The manual for my B2320 says 54" max. width, 375# for the B2320, 500# for the B2620 & B2930. The B2660 may be different, but the info is in the manual.
/ Box Scraper Weight for Kubota 2660 #6
Are we talking about a BX2660?
5' is too wide for a BX.
4' around 350-400lbs would be good. You will need front weights or a loader to hold the front down.
/ Box Scraper Weight for Kubota 2660 #7
I agree that if you get a boxblade that is too heavy, you'll just be spinning your wheels. Just set it up at the proper angle for your application, learn to use it and you'll get more accomplished with a lighter blade that is designed for a small tractor.
I recommend a box blade as wide, or just a hair wider than the outside of your rear tires. We make 48" and 54" Compact Tractor Box Blades that will work great with your tractor. They both have 4 ripper shanks so the pull isn't going to be that much more on the larger model. We also designed our 60" Compact Box Blade with 4 shanks for the same reason.
Our box blades will ship free to a business or supporting freight terminal within 1,000 miles of Newton, NC.
Here's the video. We also have quite a few how-to videos on our website that may be helpful.
Travis
/ Box Scraper Weight for Kubota 2660 #8
How much is the 48"?
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2015 Ford F-550 Crew Cab Service Truck (A61568)
2015 Ford F-550...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
3PT. PTO DRIVEN SPRAYER (A62131)
3PT. PTO DRIVEN...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
Club Car Intellitrak Golf Cart (A61166)
Club Car...
