Box blades with scarifiers that dop down with a le
   / Box blades with scarifiers that dop down with a le #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
Being new to owning ,but not running a tractor . I have a question about box blades . I used to run an old Ford 3000 with a box blade that had scarifiers that were controls by a lever .as opposed to setting the scarifiers with pins . Are these still on the market ? It sure made things simpler . And at the rate I can lose stuff , It would save me some bucks in the long run /forums/images/graemlins/smile.gif John
   / Box blades with scarifiers that dop down with a le #2
I use a 72" land pride box blade that has hydraulic retractable scarifiers on the back of our JD4400. There is also a manually retractable model available. The scarifier are also adjustable to 1",3", or 5" depth settings. Is this what you meant?
   / Box blades with scarifiers that dop down with a le #3
Yes they are still available in most mfg.
Yes . Thanks for the reply . John
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
Ford BL223C Utility Tractor (A55851)
Ford BL223C...
KUBOTA RCK48P-90T 48" MOWER DECK (A57192)
KUBOTA RCK48P-90T...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2014 Kubota BX25D (A53317)
2014 Kubota BX25D...
