Box Blade
   / Box Blade #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
I used my neighbors box blade this week-end and found that I could really use one of them. I was amazed at what I could do with it. My neighbors is a 6 foot and two of the knife slots were ripped right out of the 4 x 4 frame. I am sure someone used it with too large of a tractor and hit a large rock and just ripped the slots right out.
So this brings up a concern when buying. Who makes the best box blade as I have large rocks in my area and I would rather see the tractor come to a stop before ripping out the teeth?
murph
   / Box Blade #2
Midwest makes 3 models, I don't think you'll tear up the mid and heavy duty models of those.
   / Box Blade #3
Murph the last time that I checked Corriher's had some pretty good pricing on a box-blade.
   / Box Blade #4
If I was to use a box blade on my road do you turn the forks out or into the box blade?
   / Box Blade #5
You mean the shanks? The ripper shanks should be set so the pointy end hits the ground and tears it up allowing the box to scrape it up easier. Weight is your friend, it allows the box to dig in and pick up material instead of bounce along.
   / Box Blade #6
Murph, I have had great success with my Gearmore Box Scraper. Very heavy, no problems with the teeth and I regularly pull it with a full bucket in FWD until the wheels spin.
I just raise it out of the ground and start again.
Mark
   / Box Blade #7
Heavy duty or industrial grade would be good choices.
Gannon or Cammond. They are heavy.
I'm sure there are others that will fit what you need.
Gannon
Cammond
   / Box Blade #8
Murph, I've got a 'Bush Hog' brand "MBX" which I think is heavy duty...I'll try to attach a picture....its got 1/2" sides & 3 plates that secure the pins at the bottom 2 points.
   / Box Blade #9
What's the price range on box blades?
coffeeman
   / Box Blade #10
Hey all
I just found a thread that gives a price run down. No need to post any answers on prices of box blades; enough info next page.
Cheers...Coffeeman
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2001 NEWMAR 45FT TANDEM RV WITH 2 SLIDE OUTS (A51222)
2001 NEWMAR 45FT...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
