Box Blade Sway
   / Box Blade Sway #1
tdenny
Platinum Member
Seattle area
JD 855 4WD, HST
OK,
I just got my new box blade (First Choice) it is very nice. Works great but I'm having a small problem. When I turn relatively sharply the lower 3PT arms hit the tires. Has anybody had this problem before? I'm sure it's somewhat simple to fix I'm just not sure how. All my other attachments don't have this problem. I know that many of you TBN'ers out there use your box blade for rear ballast (seems like a good idea) but I can't do this if it is going to sway into the tires when turning. Any suggestions. Thanks.
   / Box Blade Sway #2
Sounds like you need to tighten/shorten the check chains on the 3 pt hitch (on the Kubota, you need to screw them)
   / Box Blade Sway
Snowman,
Thanks for the info. I thought perhaps that might be the case but I didn't want to mess with the check chains without checking here first to see if that might be the correct solution.
   / Box Blade Sway #4
Some folks may do it differently, but like Snowman, after hooking up my box blade, I adjusted the check chains (or bars) so that I had an absolute minimum of sway to either side.
   / Box Blade Sway #5
<font color=blue>"I just got my new box blade (First Choice)"</font color=blue>
OK, who is this really? And how did you get access to TD's account?? /w3tcompact/icons/mad.gif
Seriously, congrats on taking delivery of your new box blade. Was I right about it being heavy duty enough for you? /w3tcompact/icons/grin.gif
When do we get to see a picture of your newest addition?
   / Box Blade Sway #6
Of course this must mean that you must have gotten your new First Choice 3pt finish mower also. If you can pry yourself away long enough you have to send pictures. After all we do have to measure your smile.
   / Box Blade Sway
Gary,
Yep its me in the flesh and scooting around on my tractor with a fancy JD green box blade. Heavy duty it is. I got the -20 instead of the -30 and I'm glad I did. The -20 is plenty heavy enough for my little 855 and As I told Kodiak it works great. I'm going to get a ton of use out of that thing even though my driveway is now paved.
In fact I'm having so much fun moving dirt and rocks around and mowing everything green that I've been too lazy to get the camera and take pictures.
In order to ensure that I'm not choosing sides I got an orange mower. OK I really only got the orange one because I was tired of waiting and they were out of stock on the green ones. I tested the mower to a great extent on Sunday and will tell you that one should be careful not to set the height too low. /w3tcompact/icons/blush.gif
Next I think I'll get the aerator so I can make all that grass I'm going to plant and mow look good.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
8ft Fork Extensions (A51691)
8ft Fork...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
