Box blade size
   / Box blade size #1
70boss
Bronze Member
Madison Wis.
Had a B7500
When choosing a boxblade, do you try to buy one that is wider than your rear footprint? I don't want overburden the tractor, but I also don't want to buy to small. It will be used on a B7500 Kubota.
   / Box blade size #2
Yes you try to get one that will cover your rear tracks so you don't have to go back over the area that you did or leave tracks, etc. where you ahve already been.
   / Box blade size #3
70Boss,
Go with the width. A couple of dealers thought I could go up to a 54" or 60" blade with the B7500, but in the end I ended up with a 48" Woods. This puppy is very heavy, closely matches the width of the tractor, and stays within your traction limitations.
The GlueGuy
   / Box blade size #4
Like the other guys said, you definitely want one wider than the outside of your rear tread. My B7100 was 40", so I used a 4' box blade. My B2710 is 54" so I'm using a 5' box blade.
Bird
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
JOHN DEERE 7210R LOT NUMBER 258 (A53084)
JOHN DEERE 7210R...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
