Box Blade on wheels?
   / Box Blade on wheels? #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
It's called a speed mover and a few other names that I know of. This unit is 4' wide. I found a place that sells them. Now instead of the box blade wooptdooes this speed mover can level faster & easyer than the BB. A 3 x 8" HYD clyinder does all the work.
Is this of any interest to you guys?
DDT
Thes are built in 4'-5' & 6' wide for compact tractors.
DDT
   / Box Blade on wheels? #3
I have also heard them called dirt scapers or dirt pans. Used around here frequently in feedlots to remove manure. Most of the ones I've seen have been about 10' wide.
   / Box Blade on wheels? #4
I've never seen the little ones like that, but have a neighbor who has an 11' one. Don't know what brand it is, but it looks like an ordinary box blade with the hydraulically raised/lowered two wheels. Of course, you can pick the wheels completely up off the ground to get its full weight digging in, or you can lower the wheels and pick the blade up high enough to drive down the road with it. He and I did the parking lot for the volunteer fire department. I did the final smoothing in the tight places with my little Kubota and he did the rest with that thing behind a big Deere./w3tcompact/icons/laugh.gif
Bird
The size of it appealed to me, since i have been thinking about building one out of a box blade. I built one of a lawn mower a few years ago, it was 42" wide and worked great with ag tires and calcium. I traded a JD 318 in on a compact tractor. I let my dad use it behind the ATV on the farm. If you have never worked one you would give up your box blade (except in corners). You can get a table top effect, flat and smooth.
DDT
(3) VISSANI REFRIGERATORS (1) FRIGIDAIRE REFRIGERA (A51248)
(3) VISSANI...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
