Dirt Moving Box blade on a 850
   / Box blade on a 850 #1
DieselSJ
Deere 850
Looking at a box blade for my 850. I've been told that I want a box that is wider than my rear tires, which makes for a 6' box. Is my 850 going to be able to handle a box that big?
   / Box blade on a 850 #2
Everything will have its limits.
You will need to decide if putting up with narrower width and not engaging all the ground behind the wheel path is better/worse than taking a smaller bite.
   / Box blade on a 850 #3
If you have MFWD (4x4) and ag tires, I suspect it will pull the 6ft BB reasonably well, and do even better with the 5ft. If you don't have 4x4, you might want to consider getting the tires loaded with ballast, if not already done. As mentioned, every tractor will have limitations with just about every attachment. Whichever size you decide to get, you will have to learn how much material you can load up the BB with just before it begins to stall the tractor out. Once you learn that, you can stay within that amount and move stuff all day long. Good luck!
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Electric Mobility Scooter (A51694)
Electric Mobility...
2021 Bobcat S740...
1998 Volvo VNL64T Sleeper Truck (A52384)
1998 Volvo VNL64T...
2020 VOLVO VNL SLEEPER (A53426)
2020 VOLVO VNL...
