Box blade drops when loader lifting load
   / Box blade drops when loader lifting load #1
Sammypro
Ford 1910 4WD
Brand new here and can't find answer. When I am lifting a heavy load with the front loader the box blade slowly goes down. After the load is stable the blade will lift back up. Any ideas.
'86 Ford 1910 4WD.
Thank you
   / Box blade drops when loader lifting load #2
Sounds like a pressure issue. Is the machine low on Hydraulic fluid?
Regards,
Chris
Yes, that was my first thought. I checked the fluid and it was clean and at the high level on the dip stick in the tranny.
   / Box blade drops when loader lifting load #4
Does your box blade also descend overnight.
Using the loader should have nothing to do with the 3pt descending, as the loader gets the fluid first and the cyls are sending the fluid to the tank.
Maybe your 3pt lever is not in neutral.
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
1838 (A51248)
1838 (A51248)
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
