Box Blade DIY Hydraulic Retractable Rippers
   / Box Blade DIY Hydraulic Retractable Rippers #1
walker450
Platinum Member
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
I have an old swather that is wore out. I cut the hyd mounts off and welding it onto my box blade to raise and lower the rippers. Working on it right now, will post more pics later and a video too.
20200813_180847.jpg20200813_180949.jpg20200813_180847.jpg20200813_180840.jpg20200813_180904.jpg
   / Box Blade DIY Hydraulic Retractable Rippers #2
Great project!!!
What currently locks your scarifier in the lowered position? You must retain that!!! Can't rely on the cylinder to hold them.
When taking your pics, pull back a little. Sometimes they are so close that it's hard to tell the point. We can always "zoom" closer if we need to.
Anxious to see your progress!!
Thanks for the tip!
I actually thought the cylinder would be sufficient to hold steady. I will weld stops so I can't go too far one way or another.
Will ponder on this.
It worked, time to take it apart and weld on the actual arm im using. Will also weld stops for max up and max down.
   / Box Blade DIY Hydraulic Retractable Rippers #6
You will need a latch system to lock them in the lowered position. The cylinder and/or your linkage can't hold them.
   / Box Blade DIY Hydraulic Retractable Rippers #7
That's cool! I thought you were going to have the whole assembly rotate.... the up/down idea is great!
   / Box Blade DIY Hydraulic Retractable Rippers #8
I'm wondering why the cylinder wouldn't hold the rippers in position if the valve is in good condition. Might have to bump the lever occasionally if there is some creeping but seems that would be tolerable for a consumer grade application.
I do think that most factory made units do have a locking provision such as an over center mechanism, however.
   / Box Blade DIY Hydraulic Retractable Rippers #9
Gearmore has manual and hydraulic versions. The manual one that I have looks a lot like this one. The hydraulic version uses the same frame to hold the ripper teeth and the same pivot, like you're doing. But it's got a 1.5" hardened pin to hold the rippers in place when they're down. It's automatic somehow. I have a parts diagram but I can't make out how it works.
   / Box Blade DIY Hydraulic Retractable Rippers #10
I think the cylinder would hold them also. If the valve is centered, the hydraulic circuit is closed like a toplink, loader, or a swivel rear blade/rake positioning cylinder.
There could be some creep over time depending upon the seals in the cylinder or control valve but I wouldn’t expect a lot if any on a system in decent shape.
Great project! This is one on my back burner I want to do.
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
CAT E70B Excavator (A51573)
CAT E70B Excavator...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Pallet of 22 Misc Wheels (A51573)
Pallet of 22 Misc...
