box blade compatible?
   / box blade compatible? #1
waldoe
phoenix, az
kioti ck2510
I purchased a kioti ck2510 recently without a box blade. After using the kioti some, which I like just fine, I can already tell that the 2 speed hydrostat is not for me. One day I will update to a 3 speed hydrostat, 30 hp max. Who knows what brand it will be. I am thinking of purchasing a land pride box blade bb1260. Will this work with the newer jd quick attach, in case I end up with one, or are they all the same? Thanks
   / box blade compatible? #2
I have the JD quick attach on the 3 ph and it works great. Should be able to get a box blade that has the standard quick attach dimensions.. or if not, easily adapted to fit.
What don't you like about the 2 speed hydro? Is it the only option for the Kioti's ?
I think the next size up kioti is 3 speed. When taking small amounts of rock/dirt a distance low is to slow, high is fast enough, but need to be in low to load. medium would be just about right so you dont have to keep changing. at least for me, that is my opinion
   / box blade compatible? #4
Unless I'm moving material quite a distance, I just leave my tractor in the "digging" gear. A lot less futzing around.
Of course, I'm usually digging/scraping in 2nd or 3rd gear. No need to shift up to 4th.
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
Ford Pickup NR (A50323)
Ford Pickup NR...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2025 CFG Industrial QK20R (A50123)
2025 CFG...
2017 Bobcat MT85 (A50123)
2017 Bobcat MT85...
