Box blade blades
   / Box blade blades #1
RobS
Super Member
Goshen, IN
None!
I've noticed on my King Kutter box blade that the front cutting edge is lower than the rear (by about 3/4") when the top of the end plates etc. is horizontal. This means I really have to crank the top link out to pull the front edge up for smoothing. Is this typical?
Rob
   / Box blade blades #2
Rob, I think all the ones I've seen were even. And the front and rear cutting edges should be identical, as well as reversible. One possibility that I've seen is for the bolts holding the cutting edge on to get loose, then get dirt or gravel jammed in under the cutting edge that holds it in an unnatural position.
Bird
TRAILER AXLE (A51244)
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2013 CATERPILLAR...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
