Tractor Sizing Box Blade and Bush Hog size for a JM 354
   / Box Blade and Bush Hog size for a JM 354 #1
kbone1
St.Augustine, Florida
JM 354
I have a JM 354 with the 395E3 engine which makes it a 30hp I believe but that's OK because the torque is about the same. Anyway, I want to get a box blade and a bush hog of some type. I know my track is about 60 inches wide, but I am not sure what size box blade and bush hog my tractor can handle.
I want to be able to use each often if needed, (I may do some side jobs). What is a good size for my tractor? What are some decent brands/models that are reasonalbly priced?
Thank you,
kbone1
   / Box Blade and Bush Hog size for a JM 354 #2
Hey kbone1,
I was looking at the 354 when I found a good deal on another model and went with it. I wanted to get a rotary cutter and box blade as well. The dealer I was working with recommended a 5' rotary cutter and 5' box blade for the 354. He said the 354 would have no problems pulling each of these.
I currently have a big bee roatary cutter that I am very pleased with. Has held up real well - but - I just have one season of cutting with it. Expect many more as it appears to be well made and heavy. Have a Atlas box blade - same comments apply. Has worked real well keeping our gravel road maintained.
Know there is better equipment out there than what I have, especially for commercial type work. Not sure how well what I have would up under heavy regular usage based on comments I have read about these brands. But for me, and what I do/need them for, they are fine.
Good luck in your search.
Eddie
   / Box Blade and Bush Hog size for a JM 354 #3
I would be looking at a 6' brush hog style or finish mower style for a 354, the box blade I would look at a 7'. I bleive the 354s don't ahve creepers so tiller size I don't know if it goes slow enough
markM
   / Box Blade and Bush Hog size for a JM 354 #4
I have a 354 and use a 6 foot brush hog, 7 foot box blade and a Howse 54 inch tiller, all work just fine. The only implement I found the 354 is a little fast for is a trencher in hard ground like cutting a ditch over a packed dirt roadway or driveway.
Krupp 300 Hydraulic Hammer (A52384)
Krupp 300...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Eagle Line 3pt Single Row Plow (A50123)
Eagle Line 3pt...
3 Pallets Oil / Chemical Sock Boom (A53117)
3 Pallets Oil /...
