Red_rider
Bronze Member
Branson 3510 with > 30 hours.
I recently started noticing that my York rake was "bouncing" when I raised it all the way up. It raises and lowers fine, but when you raise it up all the way it slowly drops a couple of inches and then raises back up. It is a rhythmic thing and isn't changed by adjusting the lift speed. I can't find any leaks anywhere in the hydraulic system. The fluid level is fine. It will likely be worse when I put the blade on for snow, etc. /forums/images/graemlins/confused.gif Air in the system?????
