bought used grapple, drain hyd fluid?
   / bought used grapple, drain hyd fluid? #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I bought a like new grapple, guy only used once for cleaning up limbs and tree around his house. It has the flat face couplers I need already. He used it with a skid steer, not sure if they use different hyd fluid than tractors. My question is should I worry about the little bit of fluid in grapple 1/4" hoses, take couplers loose and drain. Or just hook up to tractor and go? I am thinking the little bit of fluid in lines would not matter and just go with it!
   / bought used grapple, drain hyd fluid? #2
I think your thinking is correct. There will not be that much hydraulic fluid in the hoses and piston(s) - - when compared to what is already in your tractor. You will probably get first hand knowledge when you hook it up to your tractor. Chances are pretty good that it will not be a "drip proof" first connection and you can see what it looks like then.
   / bought used grapple, drain hyd fluid? #3
When I have used any of my attachments on rental equipment it concerns me a bit. I always hook up the supply side to my tractor and crack the fitting on the return side. Activate a bit and flush the line out. Tighten up the fitting, hook it up to the tractor and done deal. Might be a bit excessive care but its quick and cheap and safe.
   / bought used grapple, drain hyd fluid? #4
Keep in mind the cylinders are full also if your that worried about it.
   / bought used grapple, drain hyd fluid? #5
Worry about it? No.
But, I would check the fluid that's in there. If it's not clear, then change it. Probably wouldn't take much, and if that gives you peace of mind, go for it.
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
Cat TH407C Telehandler (A53472)
Cat TH407C...
378570 (A51573)
378570 (A51573)
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
