Bought an old Mott Flail mower, but I think it will not work...
   / Bought an old Mott Flail mower, but I think it will not work... #1
mgamber
Bronze Member
Houston, TX
Kubota L3240
I was able to get a manual for it and it states it needs 1000rpm on the PTO to mow properly. My tractor only has 540.
Do they make a PTO speed doubler?
Or should I sell this flail mower and look for something else?
   / Bought an old Mott Flail mower, but I think it will not work... #2
The Mott mowers are designed to be operated at a speed of 2100 RPM when using the tractor power take-off speed of 540 RPM. The PTO speed has to be kept up.
Which Mott mower? Pretty sure mine is a J60, and in the manual it states to be used with a 1000rpm PTO speed.
Is it possible I have mis-identified the mower and it could operate with the 540 pto speed?
   / Bought an old Mott Flail mower, but I think it will not work... #4
post a picture of the mower, all mott and alamo mowers have ID numbers, look on the gear box for numbers, go to montage or flailmaster websites, or call them, far as I know mott and alamo mowers are 540
   / Bought an old Mott Flail mower, but I think it will not work... #6
I would bet its the rotor speed they are mentioning as a fuction of the PTO speed.
the rotor will spin at 100 miles an hour which is 24 revolutions per second
at the 2100 RPM rotor speed -if my math is close to right
The 1,000 rpm PTO splines are a very small cut and have many more teeth
If the male spline which exits the gearbox has larger teeth it is a 540 RPM PTO.
You can obtain male female spline adapters to convert the 540 RPM spline on the tractor to 1,000 rpm on the implement with no monkey business.
I would like to see the spline exiting the gearbox but I am sure it is a 540 RPM mower.
The spline coming out of the gearbox is indeed a smaller spline with many more teeth. It is NOT like the spline on my tractor's PTO. I am 100% positive this mower is meant to run on a tractor with 1000rpm on the pto. I have the manual, it states it in there. Someone else sent me a manual for a Mott flail mower that runs on 540rpm, but it has a completely different gear box.
   / Bought an old Mott Flail mower, but I think it will not work... #8
Oops, yours is a J60...I had assumed that it was a a 60 or 72. The small square gearbox identifies it.
The gearbox on the J60 is rated at 25hp. with a minimum input speed of 1000RPM. The tractors that it was designed for have both 540 and 1000RPM PTO speed. The mower should always be operated at 1000RPM. That's why the tractor end yoke is 1"x15spline.
yes not a mott
Yes, it is a Mott, I have the manual for the J60 "Hammerknife" and it matches exactly. Flailmaster.com has identified it from the pictures.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
UNUSED FUTURE STB47 TELESCOPIC BOOM (A51248)
UNUSED FUTURE...
2019 JOHN DEERE 8245R LOT NUMBER 187 (A53084)
2019 JOHN DEERE...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
